Note 3: Battery Woes....
rajnet
106
I am down to 5% in 6 hours with moderate usage. Any way to check rogue apps? Device is also getting heated up.
Re: Battery Woes....
Go into settings and check your battery status that will give you a good idea which apps are using the most power and some tips - turn off auto sync , turn down the brightness on your screen and log out of apps like Facebook/twitter ...
sent from my Nexus 7 using tapatalk pro..
I heard the Facebook app is notorious for draining our batteries. However I leave my on anyways :))
Sent from my Galaxy Note 3 via Tapatalk
That's probably why your battery is draining so fast lol :)
Reboot. Power down the device, pull the battery, replace, power on.
9 times out of 10 (more than this really) this works. Unless your a power user (rooted, non-stock ROMs, overclocking, etc.) who's pushed your Note.
Yup Facebook will drain it for sure!
If I don't use the Facebook app, I get almost 7 hours of battery time. If I use the Facebook app, I'll get 5-6 hours. Stinks!!
Sent From My Samsung Note 3 using Tapatalk
Download gsam battery monitor and see what is killing the battery. That is waaayyyy too fast for the battery to be dying, unless the screen was on 100% of the time.
Sent from my SM-N900V using Tapatalk
Casperxx99
