Note 3 Charging Sounds
eman619
Active member
Sep 13, 2013
39
Does your note 3 make a charging sound when you plug in your wall adapter and make a disconnection sound. My s4 did that but my note 3 doesn't.
@eman619
Having the same issues. Only vibrates when I charge my note 3, no sound. What did you do?
I've set a rule in AutomateIt (available from the play store) to do this. Works perfectly.
Mine only vibrates when I plug it in as well. I assume that none make a sound when plugged into the wall charger?
Strangely enough, the ogg files are in the root media folder, but it's not active in the stock rom. Screen on and off is also there.
Would be great if possible. I already imagine the oldskool half life sounds when I plug unplug my phone
That's also driving me nuts, too hehe All my older Galaxy devices made the sound, even the Note 10.1 2014 does it... but Note 3? Mute... ??
drove me crazy, i set tasker to make a sound when i connect power during the day. i use a wireless charger, so i like to make sure i tossed it in the right spot.
its as easy as opening play store download PLUG SOUND and wham bam thank you mam. you even get to browse your phone to select your own sound. hope this helps
xxSlayer92
