Note 3's Screen High Battery Consumption.
AG70
Hello,
Would someone please shed some light on the reason that may be causing my phone to use more than 40% of the battery for the screen? This does not make sense to me because I have enable every possible power-saving setting. I also reduced the brightness and decreased the time out length.
Thank you.
Hello,
Thank you.
Welcome to the forums.
It does take a lot of power to run a screen that size.
Just checked mine and I'm at 71% for my screen.
Sent from my Samsung Galaxy Note 3 via Tapatalk.
If you tap the screen section it will tell you how long your screen was on for.
Sent from my gameboy color
I see 40% easily on my gs3. No surprise that it's that our more on the note 3. I mean it's one of the biggest phone screens you can buy. Why wouldn't it use a lot of the battery.
Sent from my SCH-I535 using Tapatalk
Ariwenni15
