A
Android Central Question
Hi there,
I dropped my N4 from quire a short height onto the leg of a metal chair. My phone wasn't charging beyond 70%. I went to remove my battery to see if taking it in and out would fix it and I noticed to my horror the housing around the charging port was dented and bent in, albeit I can still put my charger in there and still charges.
I replaced the battery with a Samsung branded one from a local repair shop and they look identical but it really doesn't hold a charge very well. I turn my phone off at night with 100% charge. Within 2 minuets of using it it had gone down to 95%. Its now 67% and I haven't even done anything on it apart from a minuet on Instagram and on the Internet for 10 minuets. Normally it would be at least 90% if that.
What is the problem, the housing which is damaging the port or the battery? I'm taking it to a service centre but do you think it will be repairable? Its only about a month and a bit old and was a lot of money!
Any help will be much appreciated
