- May 22, 2016
- 7
- 0
- 0
Hello,
I been having problems with my battery lately, and it seems from the things i read on the internet that allot of note 4 users do have it also but no one posted a valid solution. My phone charges to 80-81-82% max. Its the same if I do it if the phone is powered off or on. I did a master reset still nothing. I did try with fast charging on and off but still the same results. When I pool the battery out and put it back in it shows 100% but when it gets to sometimes 10-15-20% it just shuts off like its drained all the way down ( witch it probably is). I did buy a new battery, and it has the same issue. Also I did try to drain it all the way down then charge it when its off, like the most tutorials say but still it wont reset the battery file in android. I wont root my phone since it is under warranty. I have a N910C model with Lollipop installed on it.
Thanks in advance.
Thanks in advance.
