Note 4 camera issues since updating to Lollipop
nicole248
4
I want to know if anyone is having issues with the camera on their Note 4 since the "Lollipop" update? My camera does not focus at all...
Galaxy S5 also has the same Camera App issue since the Lollipop install. Lollipop affected the App camera focus, also when I open the camera app the phone gets hot then does a massive battery drain. I downloaded 2 other Free Camera Apps from Google Play Store that were highly rated, Camu, and Google Camera. Both work great, very crisp focus, and both have some great features.
I haven't removed the stock app, but I haven't used it since installing the other 2.
I've heard some other people mention issues with the camera and focus. I haven't had a problem.
The Google camera was also mentioned above, I've seen very good ratings on it also and it is free in the Play Store.
Same issue here. No camera app works, can't focus image since Lollipop update. That is certainly the cause of the malfunction. Also tried downloading Google Camera, and same issue - no focus
I have no problem with my Note 4 camera focusing, either before or after Lollipop update
Sent from my SM-N910V using Tapatalk
Faded105
