Note 4 or edge plus???
NFOM
11
I currently use the s6 which has been my phone for around a year but the size is a problem for me it's just too small.... I'm stuck on what to do regards to upgrading..
Either buy a refurbished note 4 for £250 or Edge plus upgrade for £390
With the new os update will the note 4 work smoothly?
Sammuel1973
990
3
18
Assuming swappable battery and/or sd card are not an issue for you since you own the S6, go for the Edge Plus. Unless you want the SPen, the Edge Plus is closer to the S6 but bigger and with better specs overall.
Feb 13, 2016
9
My note 4 is working great still. I haven't really felt any need to upgrade. I agree with Sammuel though, if the edge isn't breaking your budget since it does seem like a pretty big gap I would just get that. Or maybe check out googles new nexus phones if those work for you?
mt20apps
