I can't imagine anyone else noticing this unless they are really into the painting/drawing apps like I am. But if you want to see for yourself and have a Note 3 stylus, please try this...
- In an app like Sketchbook, select the pencil tool with a thin stroke selected.
- With a N3 spen draw some circles as lightly as possible with a feather touch.
- Now draw some more circles next to these using the N4 spen, and try to make them as light as the N3's.
You can also try shading in a circle with each stylus. It should be next to impossible to shade an area as lightly using the N4 stylus.
You can see that the N4's stylus is blowing though the low-end pressure curve much more quickly, giving you much less range on the low end. Or... OR.. I have a bad N4 stylus(???) I hope that's the case! ...I tried replacing the tip and doing a bunch of heavy strokes to see if it just needed to be broken in. I can't see that it's helped at all. I have two spare N3 spens that are consistent with each other.
I know the N4 hardware supports twice the levels or pressure. But i'm beginning to wonder about the implementation :-\
Any confirmation or suggestions appreciated
