Note 4 Suddenly Running Very Slow
papabear4jc
65
Yesterday morning my sprint note 4 did a system update. Afterwards it was very slow. I had to pull the battery 3x due to freezing. I tried clearing the cache partition. That didn't work. I did a full system restore. It's still slow. I haven't had to pull the battery yet thankfully. Any suggestions?
taife32
103
It sounds like the update might have messed your phone up, if it doesn't improve even after system reset. So the best thing is to go to Sammobile.com and download the ROM that was before the later update. Use ODIN to flash it, don't worry it won't void your warranty as it will not trip anything
Sent from my SM-N910F using Tapatalk
papabear4jc
65
Do i need a computer to do that?
taife32
103
Yes, it's much safer as you don't want to root (I'm assuming). ODIN, will bring your phone back to the time before. Read provided instructions though and good luck.
papabear4jc
65
Interesting. The time it froze up most was using an app called meetme. It would then bleed over into everything else. I've removed meetme and everything seems to be running smoothly now.
Rometheus
128
I just got my Note 4 on Sprint last Monday. Out the box I updated to Lollipop and then started usimg like I did with my GS4. There was another update I got a few days after but it seems to be working fine. All I have done is turn on power saving mode and unchecked the Connection Optimizer. Standby time for me is good. Went to bed last night at 71% battery and woke up to 69%(slept about 8 1/2 hours).
~Blessed From My Note 4~
papabear4jc
65
I called sprint tonight. They said it's a known issue with the note 4. They're sending me a replacement but it will take 2-3 days to get here.
Rometheus
128
How long have you had yours? As stated already mine is working fine.
papabear4jc
65
I got mine back in October. But yeah the guy i talked to at sprint knew of the problem. But it's not effecting all note 4s. He said he has a note 4 and has no issues. Some people on the sprint forums said the update actually bricked their phone.
krrynew
