• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Note 8 immediately drops connection to primary WiFi but can connect to guest network
  • Thread starter Android Central Question
  • Start date
A
Note 8 utilizing Googe WiFi: After having several failures while setting up a Google Chromecast Audio, i was finally able to get the device connected and working. After doing so, my Note 8 can no longer connect to my primary home WiFi. The phone checks network settings and states a connection, but immediately drops it within half a second. The phone can however, then automatically join to my guest WiFi network on the same Google Wifi, as well as the WiFi at work or anywhere else. Further, no other device has issues connecting to my primary WiFi. I have factory reset my Google Wifi, unplugged the Chromecast audio, fully reset my Note 8 network settings and tried about everything else. Trying to to complete a factory rest on the Note, but not certain where else to look. Any help? Thanks, John
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
Look in encryption in wifi (in the router). If it's TKIP or TKIP+AES, change it to AES. If it's AES, change it to TKIP.
joplee2
I appreciate the response. However, from what I can tell Google WiFi seems to only support WPA2 PSK.
