• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Note 8 Wireless Charging Question
ccigas
4
Hey everyone, my Note 8 is coming in on Friday and with the announcement of the new iPhones, I had a question about the Note 8 or other Android phones wireless charging capabilities. In the new iPhone, you can use wireless charging to also handle CarPlay with out a wire physically going into the phone, whether how good or bad it is, is unknown but this got me thinking. Can the newer android phones like the Note 8 also handle this? Is there even an aftermarket wireless charger that could do this?
I like the idea of it since well if you want your phone to charge, it needs to be placed down and then if you really need to use it, you can use the car features.
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
They both use Qi charging, so any car wireless Qi charger should work with the Note 8, the same as with the iPhone 8.
ccigas
4
I meant the data portion of it. The new iPhone can handle data over what seems like the Qi pad in the car that they showed. Is that something new to the industry or can Android phones handle that too?
TabGuy
1,395
68
Why would would want to do that? If you remove the phone from the charger then it would break the connection to CarPlay. I bet that it wasn't Qi talking to CarPlay but the iPhone talking to CarPlay via bluetooth while sitting in the Qi charger.
ccigas
4
Well they said it was through the wireless function which seemed like the wireless charging pad. And the reason is because if you pick it up while driving, then boom you lose charging and carplay functionality which means less people would pick it up. Im guessing thats not a thing in android. no problem
TabGuy
1,395
68
One thing wrong with that assumption. It presumes that the phone, when picked up, is in the hands of the driver. Often that's not the case. I can't imagine that Apple has gone so nanny as to have CarPlay disabled if the phone is picked up.
There is no transmit function in the Qi standard. Apple is not doing this. They're using bluetooth.
Rukbat
Retired Moderator
Feb 12, 2012
44,533
18
Qi doesn't do data, just power. "Wireless" data can also mean Bluetooth, which is probably what they were referring to. I don't care what Apple does - you just can't get data through Qi, any more than you can charge the battery through Bluetooth.
