Note s9 bluetooth headset volume not loud enough
  • Start date Start date
A
Android Central Question
Bluetooth headset volume not loud enough on my Note S9,I use same headset on my S5 volume is loud.
On the assumption that you mean Note 9, moved to that forum.
Haha did you draw that circle with your toes or something? Maybe blind folded?? Good lord, son, that's how you use your S-pen??? Lol
If I could post a middle finger picture to your post without any repercussions I would. Did you have anything valid to add to the discussion or you just popped in to be a smart a**?
Yes thas the setting I meant, did it make any difference or did you have it enabled already
I have noticed the same issue with wired earbuds. I didn't try the suggested fix since mine wasn't BT. I haven't been able to find out how to get the volume up either.
I find that I often have to put my volume to the second highest level for my bluetooth headsets/earphones - in particular, my Bose Free Soundsport - but I notice that with most of my other bluetooth sets as well.
alex83
