Note4question
420benz
615
13
18
How do i turn on MTP so i can move photos into my new S10+ using ApowerManger.Thanks
I believe once you plug the s10+ with wire should a option in pull down notification panel , at least I know when u plug the phone to PC
Sorry, can you clarify -- are you trying to transfer photos by connecting your Note 4 directly to your S10+ via USB cable?
