Notification Light and Lock Screen Issues
vince24L
I have two issues which are killing my experience so far. Maybe someone here can help me out:
1. Notification Light.. Your choices are either no light or a light for every single notification. Now I use light manager but even still I only want it to light up for only sms's and missed calls. Not possible on this software is it?
Also when I get a notification and unlock, it takes 3 seconds for the notification icon to pop up on the top bar. Thats just unacceptable.
2. My lock screen never natively goes to the clock/phone icon/camera icon screen... Instead it goes automatically to 'pattern' screen or whichever lock I choose. But below the pattern is the back button that takes me to the clock screen. It should be the other way around.
Example:
Middle of the night I hit power button to check the time... Theres no clock. Instead I have to unlock with pattern and look on my homescreen.
If anyone can help me out here I'd appreciate it.
Side note: Flicking up on the physical keyboard to select the suggested word often times doesn't register. Anyone else having this issue?
Appreciate the help.
Example:
The notification lights can be turned off within each application's notification settings. That's the difference with Android; where BB10 was controlled by the OS all in one location, you now have to go into the application itself.
For the lock screen issue, you mentioned you hit the power button. Instead of that, try just double tapping the screen. It's easier to do that at night too, not having to fiddle with it to find the power button.
EDIT
Go into Settings > Display
What is the option set to? "Screen wakes to"
You can set this to either:
- Lock Screen Notifications
- Unlock
Elizabeth78
