Notification light won't flash for texts
CandleStick69
Active member
Mar 19, 2010
26
the notification light doesn't flash when i get a text on my white epic 4g touch...
and i was wondering if I could change the vibrate pattern on the STOCK messaging app.
That's the one i've been using.
Menu/Display/Make sure box checked for Notification flash; also in Messaging app go to menu/settings/Notifications - make sure box checked.
I don't believe you can change the vibrate pattern (?app in the market that will allow it)
Download Handcent from the Play Store. It lets you customize all the notification settings and you can also change the vibration pattern.
Hope this helps
