Are you using a theme from the (Themes) app? If yes, open the app.
Then open the side menu (3 horizontal lines, top left corner)
Scroll down to (Personal) and open (My themes)
Open (My current theme) scroll down to (Notification) and open it.
Blank page, Open (Sounds) from the top, Select a category.
Check the notification sounds in the selected category, you can play them online.
Download the notification sound you want to set.
After that the Download button will change into Apply, tap on it, and that's it.
