Notification Sounds Issue after ICS BAMF Leak
toastyz71
21
Yesterday I rooted my Thunderbolt and installed the ICS BAMF leaked ROM. I am having trouble with most notification sounds. Some apps won't play the assigned sound at all, and some play the wrong one. I am able to go back in and re-select the correct sound, but I am noticing that some of them are reverting to default notification sound or having no selection at all. I originally had them on the SD card, but I have also just moved them into /system/media/audio/notifications with the rest of the stock sounds. I have also rebooted into CWM and wiped cache and Davlik cache too. No change.
Any ideas?
Thanks
Seems odd, but I think I found the issue. I started using Apex Launcher after I installed the ICS ROM. I just now went back to GO Launcher, and re-set the sounds. They seem to be staying set to what I selected now.
I meant to get back to you on this, but I kind of forgot. Sorry about that. I'm glad you got Go Launcher to work for you. I think the problem with your notifications has more to do with the leaked ROM than Apex. I know some people had next to no problems with the leak, but I'm not one of them. I found plenty of glitches that made me move on to something more stable. In any case, I'm glad you figured out a fix.
whiteraice
