- Feb 2, 2011
- 83
- 0
- 0
In Samsung Gear Apps.
It allows you to answer notifications from your Gear 2 but not always. In case of whatsapp the app will allow you to reply if there are no messages unread in whatsapp, but the App is always learning. Try it!
Try to select some notifications for this App and other for Samsung Gear Manager, but no select the same notification in both Apps.
Default Screen App in only valid if you select at settings that the App asks you if you want to receive other notifications different of default supported ones.
