Oem extended 2100mah battery pooped
davey11
2,203
508
113
I've had the battery about 3 weeks now. At first I got like 10 hours with 4 hours on screen time. Nowadays it's no better than the standard battery. Maybe 7 hours with 2 1/2 hrs on screen. No discernable difference in usage.
How are you guys with the 2100mah battery doing?
This post courtesy of Tapatalk2
just a guess.... but bet if you did a factory reset, you would be back to the 10hrs with 4hrs screen time...
sadly this seems to be the case for most, including me....
I now only get about 10hrs with 2 hrs screen time...
running completely stock on 4G
-Danny
yeah not much difference whereas I thought about selling the extended and buying a second standard...but I got the extended for 25.00 at launch so it seemed like a no brainer, until finding a case became an issue.
bendre18
