Official Samsung 3000mAh extended battery arrived
anon(848791)
277
8
Just got the Samsung extended battery for my gs3. took almost 2 weeks for shipment from UK.
Awesome thing is that my existing case, which i got from Spring when i bought the phone, fit. Its a very tight fit, but it does fit. Battery is slightly heavier and the phone is slightly bulkier, but still feels nice. I will test out the battery for a few days and see how it performs, the results will be posted here.
For now, here are some pictures:
Thanks for the website. I bought mine off there and its great. What case are you using with it? None of mine fit the phone anymore. Thanks
Its a hard rubber case, almost like plastic. I used a heat gun to stretch it out a little. Now it fits perfect.
Ok, thank you. I have one of the LLOYD cases and would like to continue to use it, hopefully it will work.
Totoslulu
