One Device (Tegra Note 7) Will Not Connect to Chromecast
Nov 15, 2013
7
Hey, I tried searching in forums but its difficult to find a good keyword with my problem.
My chromecast is up and working, and two phones (an LG G2 and Nexus 4) and my laptop (an Acer Windows 8.1) can connect to it just fine, but my tablet (Tegra Note 7) Can't connect. I've tried cycling through wifi on and off, and forgetting then reconnecting to wifi, and turning the tablet and chromecast on and off. Noting seems to work.
Thanks in advance for any help.
Aquila
Retired Moderator
Feb 24, 2012
15,904
Re: One Device wont connect to Chromecast
Does it see the Chromecast and just not connect or is it not seeing it?
Kevin OQuinn
AC Team Emeritus
May 17, 2010
9,267
496
Have you taken all of the OTA's? You're also definitely connected to the same wireless network as the Chromecast correct?
Sent from my Nexus 5 using Tapatalk
Nov 15, 2013
7
Darth Spock, It does not identify the Chromecast at all, be it in the Chromecast app or another Chromecast enabled app.
Kevin O'Quinn, Yes, the device is definitely connected to the same Wi-Fi. Where I live there is only one router. And OTA's for what?
mavrrick
834
3
That is fine. By chance do you have some sort of security software on the Tegar note that might block network traffic.
I assume you have tried all the Google apps that work with the CC and not just one?
Do you have a dual band router and could the Tegra note be on the 5ghz band?
Can you connect from the tegra note to other devices on your network. And vice versa.
Posted via Android Central App on my Note 3
TexasZyph
Just got my Tegra Note7 today.
Chromecast doesn't work with my chrome browser. I reinstalled twice.
It *does* work with the YouTube app. I came here seeking an answer myself.
I'm trying to get my HBO Go working. The app says to use Chrome to cast. But I want to cast the browser in general as well.
My tech wizardry skill is rather low once I get past reinstall. Seems like a chrome specific issue if YouTube is working.
mavrrick
834
3
I don't believe casting from mobile Chrome is supported yet. I think it is still in beta.
Casting from Chrome on the desktop is though.
HBO Go has native CC support also.
neu smurph
158
Indeed it is, but so far for me it works very well - I've got Android Chrome Beta installed on my devices alongside the regular Android Chrome and have used the former to cast a variety of video from the web (works with Plex too as an alternative to the paid app).
quartetman
