OnePlus 3T Dash Charger & Anker and Quick Charge
eric0668
428
I understand the OnePlus has its one rapid technology, but you have to be using the cable and the charger Great!
Is the OnePlus able to use QuickCharge, if using a proper charge, like the Anker Wall Charger with QC ?
You can use it without a problem, you just won't get the same charging speeds as the included dash charger. I have a few aftermarket chargers as well that work perfectly fine and charge at a decent rate still. Just as long as you use a good quality charger and cable, you should be fine, which Anker generally is.
Kyle TW
