OP3/OOS 4.5.0/GSAM battery monitor
speedlever
Trusted Member
Dec 31, 2011
664
I upgraded from OOS 4.1.7 to 4.5.0 this morning without issue on my stock OP3. I use GSAM and generally after an update like this, have to go through an ADB process to enable more stats.
This time, I have not been able to make the process work. Here's the adb command I used with USB debugging enabled in developer options. Do I have something wrong with the syntax? It's worked several times in the past for me, but I may have forgotten something as it's been a while since I last had to fix this (combined app cpu vs individual app reports).
adb shell pm grant com.gsamlabs.bbm.pro android.permission.BATTERY_STATS
I verified ADB works by typing adb devices.
Has anyone else tried to enable more stats on an unrooted OP3 with OOS 4.5.0?
Disregard. I just checked the app and it is now working properly. Not sure why it took a while to take effect.
r3dpuk3
