Question Oppo f19 pro CPH2285 Stock Firmware Flash help needed.
blohsh7
Hi there, I recently updated my Oppo F19 Pro CPH2285 MT6779 to coloros13 (android 13) . However, I am experiencing slow performance and WiFi issues with this version. Previously, I had Android 12, which worked better, but I want to switch back to Android 11 as it is the best for this device.
I have been unable to flash it using guides from OppoStockROM, NeedROM, MTK Flash websites, and a few other tutorials. I also tried using ADB to boot into Fastboot mode, but it was unsuccessful, the device do restart when i enter adb fastboot command but my phone shows "The serial is not match, Fastboot_Unlock_Verify fail" and restart back into os. Recovery mode works with the Power + Volume Down button, but it only has options for online upgrade, format, restart, and power off. No flash tool is working.
I have enabled USB debugging and OEM unlocking (allowing the bootloader to be unlocked) from Developer Options, but that has not helped. I also tried flashing from local storage via the Software Update section using an OppoStockROM .zip file and needrom .rar file, but it gave a 'verification failed' error.
Welcome to Android Central forums. I see your post has been here for a few days with no replies. Have you posted this anywhere else and gotten a reply? While we have a space for Rooting and ROMs places like XDA Developers post more and talk more about rooting and ROMs so I would suggest posting there or going to where you got your ROM or rooting instructions. I do hate to send people away but in this case I think you're just fishing in the wrong pond.
Best wishes
Best wishes
I already posted on the XDA forums before posting here. I was hoping to find an answer from a different community, but still no luck. The guides I find online don’t provide a way to contact the original poster or the website itself.
Maybe @ironass might know
I am sorry but in this instance I have no first hand knowledge of the Oppo F19 Pro which I believe, was sold, primarily, in China and India in 2021.
In such a situation withe the Android 13 update, I would suggest wiping the phone's cache files to see if this helps...
As for the, "The serial is not match, Fastboot_Unlock_Verify fail", I came across this tutorial...
In case this helps, I have included a Bootloader Unlock video as well...
I am sorry that I can not be of more help.
Thanks anyway
Crusher
