Optimus f7 - LED Customization HELP
wrigty12
Hey There, so I have been trying to find some way to be able to customize the LED colors for the F7.
1) Light Flow did not do anything.
2) Light Manager never changed the color, but would actually bring up the default color for the notification (even when I had them off)
3) LED Tester was able to have the LED display different colors, but unfortunately not apply to notifications.
Has anyone successfully found a way to change the color options?
I have my led customized. I have a different color for every notification.
I rooted with framaroot.apk Gandalf exploit
Installed SuperSu which after granted superuser uninstalled the exploit.
Next installed greenify with donation package for experimental features.
From the experimental features I installed Xposed framework which allows you to customize your phone with a whole myriad of mods without changing your stock Rom.
Installed Xblast Tools mod which allows you to customize your led a million different ways. I also have a translucent status bar just like KitKat while still running 4.1.2. I don't like the lg launcher so I use Nova Prime for a much another user experience.
Screenshot is.gd/lgf7screen http://i.imgur.com/mR7h116.jpg
Sent from my LG-LG870 using Tapatalk
Alma_Evans
