oreo printer problems
Virginia Smith42
Active member
Dec 8, 2017
39
Since update to oreo 2 days ago. I cannot connect printer to system. I can print test page from printer app, but that is all. Tried thru system controls and printer search.
Try using Cloud Print. (You'll have to set it up to use your particular printer.) Share the item you want to print. Choose Cloud Print to share it with. It should print.
thanks, but found problem..Oreo, in connections, had knocked my HP printer off and replaced it w default. search the could not find mine. Also would not allow me to enter IP or host address manually. When I got rid of the default, mine popped up and all was well. Samsung help was of no help via email.
Jackwills2567
