OTA 3.29.651.5 and battery drain...
lnong
Active member
Jun 4, 2010
31
I updated with this OTA yesterday, and then rooted with Unrevoked3. I got everything to work and up running. However, I noticed the battery drained pretty quick. Anyone know what apps can be causing this in the OTA?
ok, so I went in an disabled the auto-sync feature for a few things in Account Settings, and then turn off some apps like Nascar. Then I plugged the phone back in to charge to full battery strength. Then I left the phone uncharged and unused for 6 hours, and then looked at the Battery usage. Battery level was at 70%, Cell Standby was 48%, Phone Idle was 47% and Android System was 5%. Does that look normal? or would that still seem like my battery's being drained more than it should? Cell Standby is "battery used by phone radio", so does that mean that the latest radio update I installed (Baseband 2.15.00.09.01) is the culprit?
That looks about normal to me.
I turn off my mobile data when I dont need it. Between that and a different rom/kernel I lose less than 1% per hour when sitting unused (at night when im sleeping)
That happens only sometimes for me! Other times, it'll drain like mad. It's frustrating - spare parts reports look normal, but battery drains. I need to try a different ROM and see.
Mrhord
