OTG CABLE for s21 Ultra
1814
117
Never used OTG Cable so I have a question/questions. I know they come for thumb drives, can you get them for sd cards? Are they as good as or as close to sd card slot thats on a phone? I've been thinking about getting S21 Ultra so I was curious if this would fix issue with no sd card slot on device?
I've plugged USB-C flash drives, regular USB drives with a USB-C adapter and MicroSD card readers into my S20U without problems. You may want to use a third-party file manager, the Samsung one is kind of clunky IMO.
If you want to read and write to an SD card, that's certainly doable with a USB-C card reader. If you're thinking of leaving it plugged in permanently then first, that's a horrible user experience. And second, you'd be better off with a USB-C flash drive.
jammy09
