? over my battery icon?
lysiesmommy
3
Hope I'm posting in the right place.....
So all day today my phone has been shutting its self off. It was fully charged this morning, but now my battery icon has a ? over it. I've tried searching online, but I'm just bad at the internet search thing. Anyone had this happen or know anything about it??? TIA
I have never seen this. If you are stock, and have no other programs that alter your battery display, I would call vzw tech support.
stock? meaning what? sorry i'm a total novice with most electronics!
Stock=Running the the OS that came with your Droid. Not Rooted. Not running custom ROM's.
If you didn't understand any of that, then you are running stock.
If you are still having this problem, call VZW tech support. They can, and will try to help.
i would check the manual that is for the droid. it normally can give you reference about special icons. It likely means your battery isnt working properly. not enough voltage or perhaps it cant hold a charge. did you get it wet?
LocaXion
