Overclocking
drizek
434
Anyone tried it yet?
I'm assuming the procedure should be identical to the captivate, and 1.2ghz should b possible without too much effort.
Not that this thing needs to be overclocked...
Sent from my SPH-D700 using Tapatalk
Yeah I was about to say mine is snappy enough as is and I dont want any more heat or less battery life. I have considered underclocking to ~800mhz and seeing how well it runs like that.
I'm running a widget to underclock mine currently to keep the CPU running at a minimum when the screen is off. Hopefully it might improve battery life.
I'm guessing you would need a custom kernel first. But even before that a custom recovery.
Ishimwe
