P505 stuck in CWR help..
Xery
3
I recently purchased an LG Phoenix by At&t, the problem I have is that I cannot leave ClockworkMod Recovery v5.0.2.0
I rooted it, restarted in recovery. and everything worked fine. I then upgraded my firmware, not sure what version though.. I backed up my phone before I upgraded into the new firmware. I then backedup my phone because it rebooted into recovery. Now everytime it boots it goes straight to Clockwork and I cant get out of it. I restored to my previous restore and it still doesn't work. What could I do? Should I install cwr 3? I read that cwr 5 has bugs and is known to brick phones..
Also the phone without the sd card still boots into clockworkmod menu
I have a ROM(Phoenix ULTIMATE) I'd like to flash but I'm not sure if I should right now considering I'm stuck at this menu.
Other Info-
in my restores It says;
2011-10-04.21.37.48/
2011-10-04.21.56.13/
I'v tried restoring both.
getting an error stating;
E: bad boot message "recovery"
Edit; tried flashing the phoenix, didnt work.
installation was aborted
said i needed to switch to Edify scripting, and amend scripting is no longer supported.
What could I flash too to fix this PLEASE HELP
http://forum.xda-developers.com/showthread.php?p=18129331#post18129331
I have the same problem but with my p506/thrive.... switched roms, updated firmware, then stuck in cwm, absolutely no clue what to do either!
BeastForceReviews
