Pease help accidentally wiped system data
matthewmpease
hi, so im an *****. and ill start from the beginning.
I recently rooted my sprint note 2, and attempted to flash ParanoidAndroid on it. which worked fine, but I had to download the google apps thing for the playstore to work. when I did this, my keyboard wouldn't work. tried to restart it and now for some reason its stuck in a bootloop. I am using team win recovery, and messing around with it accidentally wiped my system. when I tried to boot it up It would say, "no OS installed! are you sure you want to reboot?" until I went into "install" and installed the paranoidandroid file and now when I try to reboot it just says "your device does not appear to be rooted, install supersu? whis will root your device." when I say no don't install, it bootloops back to teamwin recovery, when I swipe yes install...it does the same thing. and to top everything off, my computer recognizes my device, but wont let me open the files. PLEASE HELP ME:(:(:(:(:(:(:(
maryhurst515
