Phone is pretty useless when data roaming
Murphy5111
548
31
Not sure what others are experiencing but when I roam even if I have three bars and am showing 3g, browsing is painfully slow (when it even works).
I have never gotten data to work at all when roaming. I get a notification saying I have no data.
Same here - I have "data roamed" once (because I showed usage). I have reported this in the Sprint forums. I can voice roam but not data. I thought I was the only one as it seems everyone else complains about "constant" roaming.
Same here. I think Sprint is slowly removing data roam usage due to tower agreements with vzw.
Samsung Galaxy S II
I'm data roaming on verizon right now so it definitely works. However, most (all?) of the time when you're roaming it's not EVDO but rather 1xrtt instead. That's why your speeds are so slow.
What app are you using that you know they are verizon towers?
There isn't. If your roaming and have a signal, your on a VZW tower. You can't roam on GSM towers at all.
The one thing I hated about the moPho, well Sprint, is that it has a GSM radio being a world phone also BUT you can't roam on domestic GSM towers. But it's all good!
No app necessary, just dial a bogus number like "48625" and wait for the recorded message which usually states the carrier. ("welcome to verizon wireless, the number you have dialed is incorrect...")
Also, OP, have you gone in to your roaming settings and disabled ALL roaming options (uncheck voice and data for domestic and international) then re-enable the DATA checkbox on domestic, and it will give you a message to re-enable VOICE as well, do that then... reboot and try one of those areas where you couldn't roam before. You have to be patient when roaming, it takes a little time for the "switch" to happen, even 30 seconds or a minute... you will see the 3G come on and you can load a page. Before doing this, when you're roaming, if you toggle airplane mode, you can get data to kick in but when the phone figures out it's roaming again, it usually will stop the process...
jnnfrmcmrphy00
