[Phone Repair Guide App] - Solutions of All Your Problems in One Place
Status
Not open for further replies.
mouaa
Download in GooglePlay :​
Are you facing problems with your Android smartphone?
Although Android is a great platform for mobile and tablet,
you may experience problems with it at one point or another,
just like any other operating systems. However, the best thing
of having an android is maximum problems has a solution.
Phone Repair Guide application that give a range of solutions to fix
of the most common problems Android owners face.So if you're experiencing problems with your phone,
You can find the solutions a quick and easy way ,in case you can not find any solution ,
with Free Users' Support Service you can send us your problem with maximal details we will help you.
- Your smartphone can't connect to your PC
- Google Play errors
- Games not working
- Screen turns off when charging
- Keyboard not working
- Syncing error with Google
- Wi-Fi not connecting
- Freeze Android smartphone and slow speed
- Battery Drain
- Insufficient space error
- WI-FI keeps dropping
- Fast-Draining Battery
- Overheating way too often
- Notifications go missing
- Why my phone screen turns itself off during calls?
- Unlock Mobile if You Forget the Pattern
- Install APK
- Error While Downloading Apps from Google Play
- Not Able to Add Widgets on Lock screen
- Battery Life Issue
- Frozen and slow UI
- Connectivity Issues
- Stalled Text Messages
- App Crashes
And More ...​
Status
pcjordanellis
