"Phone" Using %53 of my battery
Ralelen
6
Having a weird issue where "Phone" is using %53 of my battery power. I tried a reset but it is still happening. Is this common? Has anyone else experienced this?
Not quite sure what you mean. I haven't made a call since yesterday. I went to bed with %80 battery remaining, and woke up with the battery drained. Checked the power settings and "PHONE" was using % 53 of the power. Did a restart and it's still using % 53.
When you go to sleep, use TWO fingers to swipe down from the top and click to turn on Ultra Power Savings Mode. You will then lose at most 2% overnight and probably only 1%.
Restarting the phone won't change the battery used percentage amounts, you need to fully charge the phone for those to reset.
It's likely your phone app messed up and kept running in the background, restarting probably fixed it but you won't know until you are on another charge cycle.
Yea let the battery die as well it's always good to train the battery
Sent from my SM-G900T using AC Forums mobile app
Thanks. This worked.
catladyjane
