• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Phone will not charge how do i recover data
  • Thread starter Android Central Question
  • Start date
A
Got new phone wanna switch data from old dead phone
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,949
293
83
Welcome to Android Central! If you didn't back up or sync your data on the old phone, and if some of that data isn't on an SD card, then you're probably out of luck. You can't access data on a dead phone unless you bring it to a forensic data recovery specialist (which usually costs in the hundreds of dollars). This is why it's so important to keep your important data synced or backed up on a regular basis.
VidJunky
Active member
Dec 6, 2011
5,271
7
38
Do you mean that the reason for replacement was due to this charging issue or do you mean that it didn't appear to be charging. If it only appears not to be charging there's a good chance it will charge of left on the charger longer. Not sure why devices do this but they will sometimes appear to be unresponsive, especially if they've gone long periods without being charged, but if placed on a charger and allowed to charge for an hour or two they can come back to life, so to speak. Let sit for an hour, then unplug and plug it back in and see if it doesn't show some signs of charging.
