• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues, please let us know in this thread!
Phone wont load web pages
  • Thread starter Android Central Question
  • Start date
A
When my phone is connected to wifi it can load web pages but when its on mobile data it says connection interrupted although i can still connect to the gmail app and view emails as well as make and receive calls. This started happening after I turned mobile data off to save battery but nothing I have done so far has solved the issue this includes a factory reset.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,935
287
83
Welcome to Android Central! Which phone, and which carrier? I assume you turned mobile data back on, right?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,935
287
83
Assurance Wireless usually has pretty limited plans -- do you have a monthly data limit? If so, check to see if you've hit that limit.
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,935
287
83
Voice calls and mobile data are in different buckets. Does your plan include unlimited mobile data, or is there a monthly limit?
B. Diddy
Senior Ambassador
Moderator
Mar 9, 2012
161,935
287
83
You've already spoken with your carrier's customer support to see if they can help?
Does this happen in Safe Mode as well? On most Android devices, while powered on, press and hold Power until the Power Off menu appears. Press and hold the Power Off selection until the Safe Mode prompt appears. Tap OK.
