- Jun 1, 2010
- 185
- 4
- 18
UPDATE 2: SOFTWARE UPDATE FOR UCONNECT RADIOS FIXED PROBLEM
If you are having problems with Photon bluetooth connections to a Uconnect radio system and you're not sure if your radio software is the latest version, you can check it here and burn a software update on a CD and install it yourself for free following the detailed directions for your particular radio on this site:
www.mofv.com/mygig/
Fixed my problems!
2009 Dodge Journey using Uconnect system with MyGiG Navigation.
UPDATE: Exchanged Photon for brand new one at sprint store. Tried bluetooth calls as soon as activated, even before install of gmail account and all my applications. SAME problem re-occurs as discussed below. That's three different photons that do not play nice with my car. I am going to wait for a maintenance release before my 30 days is up, and if that does no fix issue, return Photon.
2009 Dodge Journey using Uconnect system with MyGiG, DVD and NAV.
My Photon pairs with the car no problem, and connects when in range. But bluetooth calls are either not made or dropped, and there is no audio on the Photon if the bluetooth call is dropped. This problem was replicated at the Sprint Store by the Sprint Rep in my car. SR paired and connected their Demo unit Photon and had the same issues.
Sprint rep says there are no known bluetooth issues, wait for Motorola to do a maintenance release or maybe that the Photon simply is not compatible with my car.
Dodge dealer says there are no firmware updates for Journey bluetooth or any known issues with Motorola phones in general and advises to wait for Motorola to update their software.
I also have had the no-audio issue during non-bluetooth calls others have experienced. Sprint rep re-activated my Photon, and said Sprint had provisioning issues when my phone was purchased last Sunday, July 31st. We'll see if that occurs again anyhow! I wonder if these are related issues!
www.mofv.com/mygig/
Fixed my problems!
