Somehow all my pictures on my SD card disappeared. The only pics I have in my gallery is a ablum cover from some music I downloaded and some wallpapers. Does anyone know if the pics are gone forever or is there a way to them back.
A reboot should get them back. Failing that, make sure you've not hidden them (Gallery | Menu | View/HIde (or similar)Somehow all my pictures on my SD card disappeared. The only pics I have in my gallery is a ablum cover from some music I downloaded and some wallpapers. Does anyone know if the pics are gone forever or is there a way to them back.
Under a standard stock software build, it sounds like you may have a file system problem on you SD card. Recommend copying off the data, formatting it, then copying the data back.So I tried SDrescan and recuva and was onlyvabke to get like 10 pics back out of 100. Does anyone know why it does this so I could prevent it in the future.
