- Nov 30, 2012
- 1,923
- 12
- 38
I'm wondering about a couple of performance parameters for the Pixel 2 XL battery. I'm not sure if the stock battery app will be able to tell you this or not. I know if you have GSam battery app it will show this, but here goes:
1. What is your average Delta % change in battery charge per hour? With GSam battery app this is easily known as it is a stat they show on the screen. Otherwise it can be calculated if you know the starting charge level, the ending charge level and the number of hours and minutes the phone was used.
2. How much percent of battery charge do you lose with the phone resting? This can be calculated most easily by observing how much charge the phone loses overnight, when it is not in use.
