Pixel 4XL screen dark with incoming phone calls
slave
723
39
28
Another day, another dumb android problem.....
So, app notification is on, as you can't turn it off. Cleared cache. Cleared storage. Rebooted phone. Default dialer. Clean sensors. No screen protector over sensors.
With incoming calls, ring tone works, but screen is dark. I have to use the power button to wake screen up, to answer calls.
Anyone else have this happen to them?
I have seen this issue happen (and read about it) on numerous different phone models. The only consistent thing seems to be all the phones use the stock Android Dialer (Phone app). It must be something related to the stock Android phone app? I have never seen an actual solution....short of factory reset of course
Does this happen consistently, or only occasionally? If it always happens, see if it goes away in Safe Mode.
ChrisAndroid
