Pixel 7 Pro system ui not responding in safe mode
LOCKtite
Hi,
i have Pixel 7 Pro with march update and after having some screen flashing problems, now i have system ui not responding in safe mode and then restarting or crashing. Why? Is google having a lot of problems with pixel phones? I wonder why march and april pixel update is delayed?
In normal mode fingerprint sensor causing a lot of problems by not working as it should.
Any help more then welcome!
Thanks
Welcome to Android Central! Sorry to hear that you're having issues. There have not been an unusual number of Pixel 7 failures reported, as far as I'm aware. Delays in the monthly updates have been more common ever since the Tensor was introduced with the Pixel 6 (most likely due to the engineers still adapting to the new silicon, which is significantly different from the old Qualcomm chips). But I don't believe this has any relation to what you're experiencing.
If the problem persists after a factory reset, then contact Google for warranty replacement.
2bit developer
