Pixel 8 pro & GMC wireless charging
reb0957
309
9
18
Anyone if a P8 Pro in a case would fit in the GMC wireless charging area? Specifically in a new 2500HD! It is still mine boggling you can only get Pro specs in a large phone!
The Pixel 8 pro is only a tiny bit larger than the Pixel 6. Less than 2mm wider and 4mm taller. Should probably be ok
Reactions: reb0957
BNIDIRECTt
