PLEASE HELP --- Home Launcher battery drain issue
lstrk
5
Does anyone have any idea why the home launcher might be taking up so much power?
I have the stock home. Nothing as widgets
If I force stop Home, or restart my phone, the power absorption goes back down to 2%
This only happens after the phone is fully charged to 100%Screenshot_2013-09-27-12-50-58.jpg
remember that the battery % listed here is % of usage not % of battery. if you aren't using apps it will be disproportionately higher.
Go to Google Play Store, download Holo Launcher HD. Is free, it's fast, it's 2.24mb. Nova Launcher is 7.51mb
Sent from my LG-D800 using Tapatalk 4
Remove unwanted ...Apps... use rambooster pro.is goood..u have to purchase...disable some. Unwanted preinstalled. Apps...your phone will be good
Yea i recently seen this on my device as well. Maybe its wedgits??
liliin
