please help how to downgrade note4 with bootloader coj5?
ahmed saad5
hello
my note 4 soft ware 5.1.1. coj5 has very bad battery performance which was very very good with 4.4.4 but with locked bootloader on coj5 i can't downgrade . any way to downgrade again to kit kat
You are correct, the locked bootloader means you cant roll back. My s6 Edge battery life was poor after mm upgrade but ive been using an app called Doze for a week or so with much improved battery life. Its on Play Store
nysmarkets
