Please help! Problem with unrooting Moto Droid!
LakersGuy89
I need to unroot my phone ASAP. I downloaded the EasyRoot app to root my phone. Was using the screenshot app with no problem. Then the Adobe Flash update came. I don't have vivid memory, but I believe my screenshot app stopped working ever since the update (I'm certain it was around that time though). Not only that, but I'm not able to unroot either. Was I supposed to unroot before downloading the update? If so, is there a way to remove the update and allow unroot?
are you still able to reboot into a customer recovery? (ex. sprecovery or clockwork). if you are, you can just place an sbf file from like the official 2.1 build onto you sd card. from there you can reboot into recovey, wipe data and cache and then install the file. that should get the job done.
please also post in the right section. there is a section dedicated to Droid Hacks/Roms
Post in the right forum - The forum index is broken down by categories. There are specific forums for applications, devices, device hacks, accessories, carriers, general chat, etc. Unique forums exist for a reason. Before you create a new thread, please ensure it is being posted in the most applicable forum. For example, threads discussing an Android application are generally not device specific, and should be posted in the Apps forum.
^^ an sbf file ;) yeah just un install the app load the official update and use a real root method I'll leave my feelings about easy root out of this. You can always just sbf your phone to frg01 then use the root method
chadreich82
