Please help,stuck in recovery !
fightu35
10
Hey guys ok heres what happen ,LG OPTIMUS V I rooted it everything worked rooted,I think my brother did a factory reset while rooted,now I cant turn my phone off !! every time it starts back up it goes into the recovery, I see the android recovery screen but I can not chose any options it just resets all and I lose everything ! any help would be great guys now its not rooted any help would be great !!
In the stickies, read LeslieAnn 's optimus v reference guide. She has links in there to threads about your problem.
Sent from my GT-P7310 using Android Central Forums
You need to flash xionia or COT recovery and use the fix boot loop option.
Tapatalk'n it from my Cold As Ice VM670 running LS670ZVJ firmware
"You need to flash xionia or COT recovery and use the fix boot loop option"
thank you for your reply,I am new with this stuff,my friend kinda rooted my cell then messed it up for me to fix.
Im not sure what you mean..
A custom recovery is software for your phone that allows you to make changes to it without fully booting up the operating system (or rom). xionia and cannibal open touch are two custom recoveries that have a "fix bootloop" option, which will help you solve your issue, and let you install a new rom.
Since you are new to this I highly recommend reading all the way through LeslieAnn's reference guide in the stickies. It is very well written, and will answer questions you didn't even know you had. She has also included three links to methods to fix your exact problem.
thank u so much for the reply,I believe I found her posts..any idea which topics I should start with..I shall read anything I need..thank u again
No problem. I love it when people want to read! Start with this one...
http://forums.androidcentral.com/op...012-optimus-v-reference-guide-start-here.html
thank you..to be a little more clear,I heard of root..so I did not,I know nothing else..lol I got super user..then gingerbreak then bam I had a rooted phone played around no if I shut my cell off everytime it starts back up all is reset I see the the android recover screen in yellow,I have no options and my cell restarts with all wiped out any help from anyone would be great ..off to read I go thank you again also I have no problem with learning but can you at least tell me what do u call what I did to my phone...seems I hit reset my phone using privacy..so I bricked it ?
Recovery bootloop. Privacy menu factory reset is a common noob mistake. It's not really bricked but requires a bit more fiddling around to fix
thank you...so its called bootloop...where should I start ! reading Iove but where to start gives me a headache
In LeslieAnn's guide there are 3 links under the section about how to recover from the factory reset.
If your rom is working
Download and install ?flash image gui? here:
http://www.mediafire.com/?bj10jcokraw7dh8
then download xonia recovery :
http://db.tt/ZKiUHnCU
Open flash image gui
Click recovery
Click browse
Go to your sd/ download folder
Find the xonia recovery img you just downloded
Install it
When youre done shut your phone off and boot into recovery by holding home, volume down, and power
You should be in xonia recovery
Find the bootloop fix option (i think its under advanced)
That should fix your bootloop
I would recommend wiping your phone and and doing a factory reset (IN RECOVERY ONLY)
And youll probably wanna go ahead and read this and flash a new rom
http://forums.androidcentral.com/showthread.php?t=108282
[HOW-TO] Simplified Root + Recovery + Custom ROM
marksains61
