• Welcome to the all-new Android Central Forums! - We're still moving some things around, so you may see a few quirks here and there, but we're working on getting things fully completed as soon as possible. For now, take a look around, and if you run into any major issues please let us know in this thread!
Please Help, Unlocked S2 Wont Connect to Wifi!
Ally Bell
Hey,
I just got an unlocked S2 (which is a huge step up from the paper weight I had before!).
Everything else is working fine on the phone but it isn't connecting to the wifi. It connected for maybe 5 mins a few hours ago but nothing else since.
Im not sure what the carrier was before, its a Koodo phone thats all I know and Im with Bell.
If anyone has any suggestions. Ive tried rebooting, airplane mode, Im not a huge techie so I don't really know what Im doing.
So any suggestions would be super helpful!
Thanks!
Ally Bell
Yeah and the old phone I had picked it up no problem, and Im on my computer right now.
dctokyo
216
Is your router open or do you need a password to join?
Connecting to wifi networks is easy, just goto Menu > Settings > Wireless and Networks > Wi-Fi Settings. From here, you can see avaliable wifi networks, and if they are password-protected. Any time you join a network, it will be saved and your device will join it automatically the next time you are in range. To forget a network, just click or long-press on the name and select "forget."
So lets delete the network that you join before on your phone and try to re-add it. sometimes this helps
