Please Help WIth ROM ToolBox Icon Switch!
May 1, 2012
15
Alright so I changed the battery icon in ROM Toolbox and it won't let me change to another icon. I can reboot with another icon but it still stays the same. Is there a way I can get back to the stock icon? Sorry extremely new at this. Thanks.
I haven't used ROM Toolbox, but when you switched the icon, did it reboot or just instantly switch it? You could try clearing cache/dalvik, or even clearing cache in the RTB app?
It had me reboot my phone after I installed it. There's also no cache to clear in the RTB app. Also how would you clear dalvik cache?
That means it probably "flashed" the change. Without restoring a backup, I think you're stuck unless it generated an undo zip.
Wiping cache/dalvik is in CWM Recovery. Cache is right there on the front menu, Dalvik is under Advanced.
Alright well I tried wiping the cache in ROM Manager and in Recovery Mode and still no luck :/ Is there anything else I can try?
asnes
