Hi everyone, I have a question on my Thunderbolt...Is it possible to change the network name that shows up when I enable the 4G mobile hotspot??? And can I change the password for it also?
Welcome to Android Central and sorry I have never used the mobile hot spot so I can't answer your question but I'm sure if you ask it in the TB forum you will get your answer.
Yes and yes... Go into the mobile hot spot app and change the settings.. mobile hotspot needs to be turned off before you can edit any of the text fields. For more help and info, stop by the Thunderbolt threads.
